Group: DynoMotion Message: 888 From: aaronkscott Date: 1/31/2011
Subject: Having problem with Kcnc spindle speed
I have been trying to get the spindle speed for DAC7 to update, but to no avail. I can set it manually in the console with DAC7=int, but when I try to set it from Kcnc I get nothing. The only way I can get the DAC to set a value is to change the scale. When I give a "S" spindle speed command, it only changes to the value set in the scale.
Here are the values I am working with.
spindle is on DAC 7 -2047 or +10.000vDC = 11500 rpm.
In tool setup screen: S>DAC setDAC=7 scale= -0.178 offset= 0 min= -2047 max=0
Exactly how does the S DAC tool setup work in Kcnc? Do I have to right a script?
Group: DynoMotion Message: 892 From: Tom Kerekes Date: 2/1/2011
Subject: Re: Having problem with Kcnc spindle speed
Hi Aaron,
That is a bug.  Here is a patch for V4.23.  Download and over write the file of the same name in the <install>\KMotion\Release directory
Or another workaround would be to set the DAC with a C Program.
Group: DynoMotion Message: 894 From: aaronkscott Date: 2/1/2011
Success. I thought I was doing something wrong.
After all this I think I may need to write ( I know I spelled it correctly this time) a simple program to continue after the spindle has gotten to speed through a digital input. But, I sincerely thank you for such a swift reply and fix.
Best regards,
Aaron Scott
> Hi Aaron,
> http://dynomotion.com/Software/FixDAC/GCodeInterpreter.dll
> From: aaronkscott <aaronkscott@...>
> Sent: Mon, January 31, 2011 12:22:30 AM
> Subject: [DynoMotion] Having problem with Kcnc spindle speed
